10-10-2012 07:34 AM - edited 03-16-2019 01:36 PM
We have a cell phone in the company that whenever this number leaves an e-mail in Exchange, it shows up as the wrong Unity Subscriber.
I have looked in exchange and unity for an association between the cell number and the incorrect user, but cannot find one.
I have verified the Caller ID is coming in to Call Manager as "Wireless Caller"
I would think somewhere in Exchange or Unity this cell is associated to the old user, am I correct?
10-10-2012 07:46 AM
It has nothing to do with Exchange, check for alternate extensions to see if this number is defined there.
Chris
10-10-2012 08:10 AM
Man, i looked at that Chris, but I didn't see anything in any of the lines.
It is at the bottom defined as Line 1.
What I see is nothing in any of the lines in the Administrator defined table, but under that in the Subscriber defined table it shows Line 1 is defined with the cell numbers.
Administrator does not seem to be able to edit this. Is the only way to edit the subscriber defined alternate number through Unity Assistant?
10-10-2012 10:03 AM
Hi Wilson,
You might be able to use the Bulk Edit utility
http://www.ciscounitytools.com/Applications/Unity/BulkEdit/Help/index.html
Cheers!
Rob
"May your heart always be joyful
May your song always be sung" - Bob Dylan
