unity recorded voice shows Rex "X"
rajesh.kumar
Level 4
Level 4
Cisco Unity 7.0 Build 7.0(2)
with IE 8.x and 6.x
when I open unity admin page http://x.x.x.x/web/sa, after login under subscriber profile and greeting,
I cant record any message, I get red "X".
It keep on asking for install web media. When I click install.
I get error on IE saying "This tab has been recovered"
I made web media install always, now i dont get prompt for install web media, seems it is automatically try for install, but I get error on IE saying "This tab has been recovered" as soon as i am in unity subscriber page.
Pls. suggest.
Rob Huffman
Hi Rajesh,
It sounds like you may be hitting this bug;
CSCtd99678            Bug Details
Unity ES patch application may not update MedaiMasENU.cab.
Symptom:
We have seen in multiple customer deployments that the application of certain
Unity Engineering Special patches may not properly update
CommServer\Web\MediaMasENU.cab and cause the Media Master bar to fail to
install when accessing Web/SA or PCA. In that situation, the Media Master bar
is replaced with a red "X".
Conditions:
Seen with Unity 7.0(2) ES 35, 31, 29, and 25.
Workaround:
On the affected Unity server, copy MediaMasENU.cab from
CommServer\cscoserv\ciscopca\controls to CommServer\Web, replacing the version
of that file already present in that destination directory.
StatusStatus
Fixed
Severity Severity
3 - moderate
Last Modified Last Modified
In Last Year
Product Product
Cisco Unity Unified Messaging
Technology Technology
1st Found-In 1st Found-in
7.0(2)
Fixed-In Fixed-in
Release-Pending
Cheers!
Rob
