Unity Script Error
karamalomari
i have generated a unity script and tried to applied on the auto attendant propmt but i am getting an error(attached)
Any help will be highly appreciated.
The unity version is 7
dksingh
It seems there is some error in the script itself...either a missing variable/parameter
or missing a step.
Did you use Express Editor (built into the CUE GUI) or the standalone app to create
your script ?
If standalone app, did u make sure that u used the version of editor app according to
CUE s/w ver ? Standalone Editor App also has way to validate scripts created.
If u can provide the script, I can tell u more. Also let me know the CUE version.
DK
