Unknown number from IP Phone
ericdegboevi
Hi all,
I have a call manager 4.0 running and a voice gateway configured with DID.
When i call from my GSM phone to the IP phone the number doesn,t appear on the IP Phone.
How can i make it appear
Note: I m using FXO port not E1
Eric
jbarcena
Level 9
Level 9
Is your GW configured as MGCP or H.323?
caller ID is not supported on FXO with MGCP.
Beside the the MGCP issue it appears that caller-in on DID lines is not supported on 4FXS/DID card.
In which country is this. ? What is the DID signaling scheme ?
I couldn't even get confirmed from discussion in another thread, that caller id on DID is supported by some telco in the US.
The gateway is H.323
thks
I recommend you to take a debug on the GW and a CCM detailed trace to see exactly what the GW is receving/sending and also what the CCM is sending/translating.
