Unusual Behavior from VG350 and CUCM 10 when adding DN to Gateway
ThomasD
Beginner
Beginner
Hi guys, hopefully you can help me out. I have an environment running a CUCM 10 cluster managing our VoIP phones and 2 VG350 Analog Gateways. The vg350's are configured for MGCP and DN's are assigned through the CUCM GUI. The issue I seem to have is that after adding a DN to the gateway on a specific voice port, the line will not register. After some looking it was determined that the dial-peer is not being generated when apply config is used from call manager. Once I run a shut, no shut command on the voice port, the dial peer is created and the line registers with the call manager. I was told that this is not expected behavior. My initial thought was a missing config item in the gateway or possibly a firmware issue. Any thoughts will be much appreciated. Firmware version is 15.4(3)m3.
Chris Deren
Hall of Fame Master Hall of Fame Master
Hall of Fame Master
Please post your GW configuration (show run).
ThomasD
Beginner
Beginner
Building configuration...
Current configuration : 14030 bytes
! Last configuration change at 08:34:54 MST Mon Dec 11 2017 by tlaird
version 15.4
no service pad
service timestamps debug datetime
service timestamps log datetime
service password-encryption
boot-start-marker
boot-end-marker
no logging console
enable secret 5 $1$YRcl$QJQnwK8DIbSL7mXE/7uXx.
no aaa new-model
clock timezone MST -7 0
clock summer-time MDT recurring
no ip domain lookup
ip domain name adams.edu
ip cef
no ipv6 cef
voice-card 0
voice service voip
fax protocol t38 nse force version 0 ls-redundancy 0 hs-redundancy 0 fallback none
license udi pid VG350-SPE150/K9 sn FOC204154T9
license accept end user agreement
license boot module vg350 technology-package uck9
hw-module pvdm 0/0
hw-module sm 2
hw-module sm 4
interface Embedded-Service-Engine0/0
no ip address
shutdown
interface GigabitEthernet0/0
description Voice VLAN
ip address 10.4.0.111 255.255.255.0
duplex auto
speed auto
interface GigabitEthernet0/1
no ip address
shutdown
duplex auto
speed auto
interface GigabitEthernet0/2
no ip address
shutdown
duplex auto
speed auto
ip forward-protocol nd
no ip http server
no ip http secure-server
ip route 0.0.0.0 0.0.0.0 10.4.0.254
control-plane
voice-port 2/0/0
voice-port 2/0/1
voice-port 2/0/2
voice-port 2/0/3
voice-port 2/0/4
voice-port 2/0/5
voice-port 2/0/6
voice-port 2/0/7
voice-port 2/0/8
voice-port 2/0/9
voice-port 2/0/10
voice-port 2/0/11
voice-port 2/0/12
voice-port 2/0/13
voice-port 2/0/14
voice-port 2/0/15
voice-port 2/0/16
voice-port 2/0/17
voice-port 2/0/18
voice-port 2/0/19
voice-port 2/0/20
voice-port 2/0/21
voice-port 2/0/22
voice-port 2/0/23
voice-port 2/0/24
voice-port 2/0/25
voice-port 2/0/26
voice-port 2/0/27
voice-port 2/0/28
voice-port 2/0/29
voice-port 2/0/30
voice-port 2/0/31
voice-port 2/0/32
voice-port 2/0/33
voice-port 2/0/34
voice-port 2/0/35
voice-port 2/0/36
voice-port 2/0/37
voice-port 2/0/38
voice-port 2/0/39
voice-port 2/0/40
voice-port 2/0/41
voice-port 2/0/42
voice-port 2/0/43
voice-port 2/0/44
voice-port 2/0/45
voice-port 2/0/46
voice-port 2/0/47
voice-port 2/0/48
voice-port 2/0/49
voice-port 2/0/50
voice-port 2/0/51
voice-port 2/0/52
voice-port 2/0/53
voice-port 2/0/54
voice-port 2/0/55
voice-port 2/0/56
voice-port 2/0/57
voice-port 2/0/58
voice-port 2/0/59
voice-port 2/0/60
voice-port 2/0/61
voice-port 2/0/62
voice-port 2/0/63
voice-port 2/0/64
voice-port 2/0/65
voice-port 2/0/66
voice-port 2/0/67
voice-port 2/0/68
voice-port 2/0/69
voice-port 2/0/70
voice-port 2/0/71
voice-port 4/0/0
voice-port 4/0/1
voice-port 4/0/2
voice-port 4/0/3
voice-port 4/0/4
voice-port 4/0/5
voice-port 4/0/6
voice-port 4/0/7
voice-port 4/0/8
voice-port 4/0/9
voice-port 4/0/10
voice-port 4/0/11
voice-port 4/0/12
voice-port 4/0/13
voice-port 4/0/14
voice-port 4/0/15
voice-port 4/0/16
voice-port 4/0/17
voice-port 4/0/18
voice-port 4/0/19
voice-port 4/0/20
voice-port 4/0/21
voice-port 4/0/22
voice-port 4/0/23
voice-port 4/0/24
voice-port 4/0/25
voice-port 4/0/26
voice-port 4/0/27
voice-port 4/0/28
voice-port 4/0/29
voice-port 4/0/30
voice-port 4/0/31
voice-port 4/0/32
voice-port 4/0/33
voice-port 4/0/34
voice-port 4/0/35
voice-port 4/0/36
voice-port 4/0/37
voice-port 4/0/38
voice-port 4/0/39
voice-port 4/0/40
voice-port 4/0/41
voice-port 4/0/42
voice-port 4/0/43
voice-port 4/0/44
voice-port 4/0/45
voice-port 4/0/46
voice-port 4/0/47
voice-port 4/0/48
shutdown
voice-port 4/0/49
voice-port 4/0/50
voice-port 4/0/51
voice-port 4/0/52
voice-port 4/0/53
voice-port 4/0/54
voice-port 4/0/55
voice-port 4/0/56
voice-port 4/0/57
voice-port 4/0/58
voice-port 4/0/59
voice-port 4/0/60
voice-port 4/0/61
voice-port 4/0/62
voice-port 4/0/63
voice-port 4/0/64
voice-port 4/0/65
voice-port 4/0/66
voice-port 4/0/67
voice-port 4/0/68
voice-port 4/0/69
voice-port 4/0/70
voice-port 4/0/71
mgcp
mgcp call-agent 10.4.0.52 2427 service-type mgcp version 0.1
mgcp rtp unreachable timeout 1000 action notify
mgcp modem passthrough voip mode nse
mgcp package-capability rtp-package
mgcp package-capability sst-package
mgcp package-capability pre-package
mgcp default-package fxr-package
no mgcp package-capability res-package
no mgcp timer receive-rtcp
mgcp sdp simple
mgcp bind control source-interface GigabitEthernet0/0
mgcp bind media source-interface GigabitEthernet0/0
mgcp behavior rsip-range tgcp-only
mgcp behavior comedia-role none
mgcp behavior comedia-check-media-src disable
mgcp behavior comedia-sdp-force disable
mgcp profile default
sccp local GigabitEthernet0/0
ccm-manager music-on-hold
ccm-manager redundant-host 10.4.0.51
ccm-manager mgcp
no ccm-manager fax protocol cisco
ccm-manager config server 10.4.0.52
ccm-manager config
ccm-manager sccp local GigabitEthernet0/0
dial-peer voice 99920991 pots
service mgcpapp
port 2/0/1
dial-peer voice 99920999 pots
service mgcpapp
port 2/0/9
dial-peer voice 99920992 pots
service mgcpapp
port 2/0/2
dial-peer voice 999201990 pots
service mgcpapp
port 2/0/10
dial-peer voice 99920990 pots
service mgcpapp
port 2/0/0
dial-peer voice 999201992 pots
service mgcpapp
port 2/0/12
dial-peer voice 99920993 pots
service mgcpapp
port 2/0/3
dial-peer voice 99920994 pots
service mgcpapp
port 2/0/4
dial-peer voice 99920995 pots
service mgcpapp
port 2/0/5
dial-peer voice 99920996 pots
service mgcpapp
port 2/0/6
dial-peer voice 99920997 pots
service mgcpapp
port 2/0/7
dial-peer voice 99920998 pots
service mgcpapp
port 2/0/8
dial-peer voice 999201993 pots
service mgcpapp
port 2/0/13
dial-peer voice 999201991 pots
service mgcpapp
port 2/0/11
dial-peer voice 999201994 pots
service mgcpapp
port 2/0/14
dial-peer voice 999201995 pots
service mgcpapp
port 2/0/15
dial-peer voice 999201996 pots
service mgcpapp
port 2/0/16
dial-peer voice 999201997 pots
service mgcpapp
port 2/0/17
dial-peer voice 999201998 pots
service mgcpapp
port 2/0/18
dial-peer voice 999201999 pots
service mgcpapp
port 2/0/19
dial-peer voice 999202990 pots
service mgcpapp
port 2/0/20
dial-peer voice 999202991 pots
service mgcpapp
port 2/0/21
dial-peer voice 999202992 pots
service mgcpapp
port 2/0/22
dial-peer voice 999202993 pots
service mgcpapp
port 2/0/23
dial-peer voice 999202994 pots
service mgcpapp
port 2/0/24
dial-peer voice 999202995 pots
service mgcpapp
port 2/0/25
dial-peer voice 999202996 pots
service mgcpapp
port 2/0/26
dial-peer voice 999202997 pots
service mgcpapp
port 2/0/27
dial-peer voice 999202998 pots
service mgcpapp
port 2/0/28
dial-peer voice 999202999 pots
service mgcpapp
port 2/0/29
dial-peer voice 999203990 pots
service mgcpapp
port 2/0/30
dial-peer voice 999203991 pots
service mgcpapp
port 2/0/31
dial-peer voice 999203992 pots
service mgcpapp
port 2/0/32
dial-peer voice 999203993 pots
service mgcpapp
port 2/0/33
dial-peer voice 999203994 pots
service mgcpapp
port 2/0/34
dial-peer voice 999203995 pots
service mgcpapp
port 2/0/35
dial-peer voice 999203996 pots
service mgcpapp
port 2/0/36
dial-peer voice 999203997 pots
service mgcpapp
port 2/0/37
dial-peer voice 999203998 pots
service mgcpapp
port 2/0/38
dial-peer voice 999203999 pots
service mgcpapp
port 2/0/39
dial-peer voice 999204990 pots
service mgcpapp
port 2/0/40
dial-peer voice 999204991 pots
service mgcpapp
port 2/0/41
dial-peer voice 999204992 pots
service mgcpapp
port 2/0/42
dial-peer voice 999204993 pots
service mgcpapp
port 2/0/43
dial-peer voice 999204994 pots
service mgcpapp
port 2/0/44
dial-peer voice 999204099 pots
service mgcpapp
port 2/0/40
dial-peer voice 999204995 pots
service mgcpapp
port 2/0/45
dial-peer voice 999204199 pots
service mgcpapp
port 2/0/41
dial-peer voice 999204599 pots
service mgcpapp
port 2/0/45
dial-peer voice 999204996 pots
service mgcpapp
port 2/0/46
dial-peer voice 999204997 pots
service mgcpapp
port 2/0/47
dial-peer voice 999204998 pots
service mgcpapp
port 2/0/48
dial-peer voice 999204999 pots
service mgcpapp
port 2/0/49
dial-peer voice 999205990 pots
service mgcpapp
port 2/0/50
dial-peer voice 999205991 pots
service mgcpapp
port 2/0/51
dial-peer voice 999205992 pots
service mgcpapp
port 2/0/52
dial-peer voice 999205993 pots
service mgcpapp
port 2/0/53
dial-peer voice 999205994 pots
service mgcpapp
port 2/0/54
dial-peer voice 999205995 pots
service mgcpapp
port 2/0/55
dial-peer voice 999205996 pots
service mgcpapp
port 2/0/56
dial-peer voice 999205997 pots
service mgcpapp
port 2/0/57
dial-peer voice 999205998 pots
service mgcpapp
port 2/0/58
dial-peer voice 999205999 pots
service mgcpapp
port 2/0/59
dial-peer voice 999206990 pots
service mgcpapp
port 2/0/60
dial-peer voice 999206991 pots
service mgcpapp
port 2/0/61
dial-peer voice 999206992 pots
service mgcpapp
port 2/0/62
dial-peer voice 999206993 pots
service mgcpapp
port 2/0/63
dial-peer voice 999201499 pots
service mgcpapp
port 2/0/14
dial-peer voice 999206994 pots
service mgcpapp
port 2/0/64
dial-peer voice 999206995 pots
service mgcpapp
port 2/0/65
dial-peer voice 999206996 pots
service mgcpapp
port 2/0/66
dial-peer voice 999206997 pots
service mgcpapp
port 2/0/67
dial-peer voice 999206998 pots
service mgcpapp
port 2/0/68
dial-peer voice 999206999 pots
service mgcpapp
port 2/0/69
dial-peer voice 999207990 pots
service mgcpapp
port 2/0/70
dial-peer voice 999207991 pots
service mgcpapp
port 2/0/71
dial-peer voice 999207099 pots
service mgcpapp
port 2/0/70
dial-peer voice 99940099 pots
service mgcpapp
port 4/0/0
dial-peer voice 99940199 pots
service mgcpapp
port 4/0/1
dial-peer voice 99940299 pots
service mgcpapp
port 4/0/2
dial-peer voice 99940399 pots
service mgcpapp
port 4/0/3
dial-peer voice 99940499 pots
service mgcpapp
port 4/0/4
dial-peer voice 99940599 pots
service mgcpapp
port 4/0/5
dial-peer voice 99940699 pots
service mgcpapp
port 4/0/6
dial-peer voice 999407199 pots
service mgcpapp
port 4/0/71
dial-peer voice 999407099 pots
service mgcpapp
port 4/0/70
dial-peer voice 999406999 pots
service mgcpapp
port 4/0/69
dial-peer voice 999406899 pots
service mgcpapp
port 4/0/68
dial-peer voice 999406799 pots
service mgcpapp
port 4/0/67
dial-peer voice 999406699 pots
service mgcpapp
port 4/0/66
dial-peer voice 999406599 pots
service mgcpapp
port 4/0/65
dial-peer voice 999406499 pots
service mgcpapp
port 4/0/64
dial-peer voice 999406399 pots
service mgcpapp
port 4/0/63
dial-peer voice 999406299 pots
service mgcpapp
port 4/0/62
dial-peer voice 999406199 pots
service mgcpapp
port 4/0/61
dial-peer voice 999406099 pots
service mgcpapp
port 4/0/60
dial-peer voice 999405999 pots
service mgcpapp
port 4/0/59
dial-peer voice 999405899 pots
service mgcpapp
port 4/0/58
dial-peer voice 999405799 pots
service mgcpapp
port 4/0/57
dial-peer voice 999201099 pots
service mgcpapp
port 2/0/10
dial-peer voice 999405699 pots
service mgcpapp
port 4/0/56
dial-peer voice 999405599 pots
service mgcpapp
port 4/0/55
dial-peer voice 999405499 pots
service mgcpapp
port 4/0/54
dial-peer voice 999405399 pots
service mgcpapp
port 4/0/53
dial-peer voice 999405299 pots
service mgcpapp
port 4/0/52
dial-peer voice 999405199 pots
service mgcpapp
port 4/0/51
dial-peer voice 999405099 pots
service mgcpapp
port 4/0/50
dial-peer voice 999404999 pots
service mgcpapp
port 4/0/49
dial-peer voice 999404899 pots
service mgcpapp
port 4/0/48
dial-peer voice 99940799 pots
service mgcpapp
port 4/0/7
dial-peer voice 99940899 pots
service mgcpapp
port 4/0/8
dial-peer voice 99940999 pots
service mgcpapp
port 4/0/9
dial-peer voice 999401099 pots
service mgcpapp
port 4/0/10
dial-peer voice 999401199 pots
service mgcpapp
port 4/0/11
dial-peer voice 999401299 pots
service mgcpapp
port 4/0/12
dial-peer voice 999401399 pots
service mgcpapp
port 4/0/13
dial-peer voice 999401499 pots
service mgcpapp
port 4/0/14
dial-peer voice 999401599 pots
service mgcpapp
port 4/0/15
dial-peer voice 999201199 pots
service mgcpapp
port 2/0/11
dial-peer voice 999402599 pots
service mgcpapp
port 4/0/25
dial-peer voice 999402499 pots
service mgcpapp
port 4/0/24
dial-peer voice 999402699 pots
service mgcpapp
port 4/0/26
dial-peer voice 999402799 pots
service mgcpapp
port 4/0/27
dial-peer voice 999402899 pots
service mgcpapp
port 4/0/28
dial-peer voice 999402999 pots
service mgcpapp
port 4/0/29
dial-peer voice 999201299 pots
service mgcpapp
port 2/0/12
banner motd ^C Private System, Do not log on unless authorized ^C
line con 0
exec-timeout 0 0
logging synchronous
line aux 0
line 2
no activation-character
no exec
transport preferred none
stopbits 1
line vty 0 4
privilege level 15
login local
transport input ssh
scheduler allocate 20000 1000
sntp server 10.100.11.27
sntp server 10.100.11.72
end
jconyers
Beginner
Beginner
Did you ever figure this out? I am having the same problem on not only my VG350, but all my other VG's as well. I have the same MGCP and ccm-manager config as you minus the binding source line, which I didn't think was necessary. Why is CUCM not generating the dial-peers when I click apply config on the port I just configured, or even when I reset the gateway from CUCM? I need to go in an build the dial peers manually via CLI and then do a no mgcp and mgcp for it to register again. Any help is greatly appreciated.
Recognize Your Peers
