Upgrade 6.0 to 6.1(2)
jecheand
Hi, i have an upgrade from CUCM 6.0.1 to 6.1.2 So i will use the UCSInstall procedure
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/rel_notes/6_1_2/cucm-rel_note-612.html#wp396032
Do i need any essential or ucss to make it work with cucm 6.1 after the upgrade?
Thanks in advanced,
Jose
Rob Huffman
Hi Jose,
UCSS is not required for this upgrade :) UCSS will be needed when you want to migrate to a new "major" CUCM version like CUCM 7.x
Essential Operate Services or "Smartnet" is a requirement for this "minor" version upgrade.
Have a look at the attached doc for a nice overview.
Hope this helps!
Rob
