12-09-2012 04:46 AM - edited 03-16-2019 02:37 PM
Hello all,
I am having CME 8.6 having current IOS " c2900-universalk9-mz.SPA.151-4.M4.bin " with following licenses installed:
License Info:
License UDI:
Device# PID SN
*0 CISCO2921/K9 FGL16371083
Technology Package License Information for Module:'c2900'
Technology Technology-package Technology-package
Current Type Next reboot
ipbase ipbasek9 Permanent ipbasek9
security securityk9 Permanent securityk9
uc uck9 Permanent uck9
data None None None
i need to upgrade to CME 9.1 to use Jabber.
Can i upgrade the IOS from 15.1(4) to 15.2(4) without any additional licenses or i need to purchase extra licenses for cme 9.1 ?
Anis
12-09-2012 07:51 AM
Yes you can as long as you have support on your router. Licenses will carry over.
HTH,
Chris
06-12-2013 10:17 AM
why is important to have support? to download the CME?.. some technical documentation to make this upgrade will very aprecciated, thnks!
06-12-2013 12:07 PM
Because without support, if your router fails, you have to pay yourself for replacement.
And, you have no access to software update, and no technical support.
All the documentation is on cisco.com if you could take the time searching.
