Upgrade compatibility
manuelosorio
Hello folk!
CUCM 14SU3 Compatibility with Expressway x8.11.3 ?
IMP 14SU3 Compatibility with Expressway x8.11.3 ?
CUCM 14SU3 Compatibility with CCX 11.6(2) ES08-13 ?
IMP 14SU3 Compatibility with CCX 11.6(2) ES08-13 ?
Cisco Expressway X14.3 Compatibility with CUCM and IMP 11.5(1)SU6 ?
For the last part of your list please see this picture.
Response Signature
You should be able to find all that information in the compatibility matrix. Please see this link Cisco Collaboration Systems Release Compatibility Matrix
Response Signature
Thank you Roger, I was reading it, but it is unclear
At least for CCX it’s pretty clear. The minimum version with CM 14 is 12.5(1)SU1. There is also a note for Expressway where it states that earlier versions than X14.0 can work, as long as no function from X14 is used. That said the version you’re asking about is very old and it’s advisable to upgrade to a current version.
Response Signature
Response Signature
