06-27-2018 05:30 AM - edited 03-17-2019 01:06 PM
Hi! I have a question about an upgrade from Cucm 11.0.1a to CUCM 11.5. I have a standalone PLM v11.0
Do I need a re-host licensing process after I'm upgrading PLM to v11.5?
Thank you!
Solved! Go to Solution.
06-27-2018 07:17 AM
You shouldn't need to, licenses are per major release. If you look at your PLM they all should end in (11.x)
06-27-2018 05:39 AM
I just checked the release notes and cannot find any reference to that:
06-27-2018 07:17 AM
06-27-2018 11:30 PM
