05-18-2014 03:36 AM - edited 03-16-2019 10:50 PM
Hi All,
I was upgrading my CUCM to 8.5 t o 9.1. I am done with ciscocm.refresh_upgrade_v1.2.cop.sgn file installation. I started the upgrade through Install/Upgrade GUI and I got bit delayed in taking the DVD out after finishing the loading from DVD so the server started booting up from the DVD and reached the media check screen. I took the DVD out and rebooted the server and got the below error.
"The partition table on device sda ( Unigen PQS800 7640 MB ) was unreadable. To create new partition it must be initialized, causing the loss of ALL DATA on this drive. The operation will override any previous installation choices about wich drives to ignore. Would you like to initialize this drive, erasing ALL DATA."
Can you suggest what is this error?
Lajith P
Solved! Go to Solution.
05-18-2014 09:07 PM
Just to confirm if this is a virtual environment? The .cop you mentioned now is at v1.3 which might be needed.. Also check if it is necessary to apply ciscocm.vmware-disk-size-reallocation-1.0.cop (if virtual deployment) they are all available on the Call Manager 9.1 utilities download section.
05-18-2014 05:43 AM
05-18-2014 09:07 PM
05-19-2014 10:01 AM
You should try using the recovery CD to switch back to the inactive partition if possible then run the upgrade process again.
05-21-2014 01:14 AM
There was yes / no option to choose and I chose No option. Upgrade finished with success. The problem was there was an usb stick / sda device present in the system. Either we can remove the sda device and reboot the system or we can continue with "no" option.
05-19-2014 06:59 PM
No. The cucm runs on MCS 7845H3.
