Upgrade from 4.1 to 6.1
jacob0911
Need information for Upgrading Call Manager 4.1 to 6.1 . I belive that DMA is required to do the same...How do we order DMA on COnfigurator..or is there any Partcode for DMA..
Rob Huffman
Hi Jacob,
The DMA Tool is available for download via CCO Software Downloads;
Data Migration Assistant User Guide Release 6.1(2)
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/dma/6_1_2/dmaug612.html
Obtaining DMA
If you do not have DMA software on a disk, perform the following steps to download it to the Cisco Unified Communications Manager publisher server. Only a registered user of Cisco.com can download this software.
Procedure
Step 1 Go to this URL:
http://www.cisco.com/pcgi-bin/tablebuild.pl/callmgr-61
Step 2 Select DMA file.
Step 3 Follow the prompts and provide the required information to download the software.
This is the actual download link;
http://tools.cisco.com/support/downloads/go/PlatformList.x?sftType=Unified+Communications+Manager+Data+Migration+Assistant&mdfid=281023410&treeName=Voice+and+Unified+Communications&mdfLevel=Software%20Version/Option&url=null&modelName=Cisco+Unified+C...
Via these steps from the Software download site
Voice and Unified Communications > Cisco Unified Communications Manager Version 6.1 > Unified Communications Manager Data Migration Assistant > 6.1(2)
Check out the compatibility here;
Table 133;
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/compat/ccmcompmatr.html#wp1533139
Hope this helps!
Rob
