Upgrade unity express 2.1 to 7:x
A client has unity express NM-CUE and wish to upgrade to unity express 7.x
it would be possible or it would be better to get a new module with ver 7.x.
> sh software versions
Installed Packages:
- Bootloader (Primary) 1.0.17
- Global 2.1.1
- Voice Mail 2.1.0
- Bootloader (Secondary) 2.0.0
- Core 2.1.0
- Installer 2.1.0
- Auto Attendant 2.1.0
Rob Huffman
Hi Filiberto,
It looks like a new module would be required :)
**Note: The NM-CUE, NM-CUE-EC are no longer supported beginning with Cisco Unity Express version 7.1.1. Cisco Unity Express on the ISM-SRE-300-K9 module and the AIM2-CUE module are supported beginning with Cisco Unity Express version 7.1.2.
http://www.cisco.com/en/US/docs/voice_ip_comm/unity_exp/rel7_1/install/prereq.html
Hope this helps!
Rob
Rob Huffman
Hi Filiberto,
Hope this helps!
Rob
Thanks a lot Rob,
Thanks for your time and for your clear comments.
