09-03-2014 12:30 AM - edited 03-17-2019 12:00 AM
In case of upgrading Cisco call manager 3.3 version,as i know that with ics 7750 we can upgrade to the version 4.0,my question after upgrading 4.x to go latest version how migration happens ?what steps i need to follow? is it possible we can upgrade the 3.X version? suggest me folks
09-03-2014 01:00 AM
Hi Siva
To reach the latest version of CUCM starting from 3.3 you need different upgrade steps.
The very first is to upgrade 3.3 to 4.2 and than to 7.1 via DMA.
Here is a doc where you can find different upgrade options.
http://www.cisco.com/c/en/us/support/unified-communications/unified-communications-manager-callmanager/products-installation-guides-list.html
Carlo
09-03-2014 01:47 AM
Hi Siva,
your tasks for upgrades would be from version 3 ---> 4 . then , from 4----> 7. I suppose same hardware u are going to use from version 3 to 7 .
What is the hardware u are using for upgrade from 3 to 7?
U are correct, VM is supported from 8.
regds,
aman
09-03-2014 01:56 AM
Aman,
You are exactly rite,from 4 to 7 i need to go for a different hardware am i rite,as u said from 7--10 i can upgrade through PCD,,,So in this case i don't want upgrade to 8 to support VM?
09-03-2014 02:06 AM
Siva,
there is no point upgrading to 8 . From 7 , u can go to version using PCD.
you can also refer the link
https://communities.cisco.com/message/120532
regds,
aman
09-03-2014 01:08 AM
Hi ,
From CCM 4 , u can upgrade to version 7.1(3).
U need to download Data Migration Assistant Tool and run on Call Manager 4.
you can refer notes of DMA and download DMA tool
http://www.cisco.com/c/en/us/td/docs/voice_ip_comm/cucm/dma/7_1_3/dma-rel_note-713.html
http://software.cisco.com/download/release.html?mdfid=282421166&softwareid=282074290&release=7.1(5)&relind=AVAILABLE&rellifecycle=&reltype=latest
I can find DMA 7.1(5) also .You can try downloading same and upgrade to CUCM 7.1.(5).From CUCM 7.1(5), use PCD to go version 10.
regds,
aman
09-03-2014 01:39 AM
Aman,
In this case i should deploy PCD in VM environment,then i can upgrade to latest version.,but as i seen in compatiblity matrix VM supports from the version 8.X.,this make me confused!
