Upgrading IP Phone software for phones on CUCMs
Earl Kacin
                   Do I need to install the upgrade file to the publisher and subcriber or just the publisher cucm?
Jaime Valencia
You need to install it on the TFTP servers the phones are looking at for their FW
java
if this helps, please rate
www.cisco.com/go/pdihelpdesk
java
the tftp option points to both cucms...so yes on both ?
correct
java
java
