Upgrading SW- CCME-UL-79xx to Communication Manager License
rodoneal09
I have read in Cisco Unified Communication Mansager Express 8.6 guide that you can upgrade CUCME license to Communications Manager.   The questions that I have are:
1) What is the cost to go from CUCME to Communications Manager
2) Does the CUCME need to be under any UCSS or ESW licensing
3) Could I go from CUCME 6.0 to Communication Manager 8.6, if yes are there any steps that I need to be aware of
Thanks!
paolo bevilacqua
1. contact an UC certified Cisco partner.
2. No.
3. The selected partner will work out an upgrade plan.
ronpatel
Level 8
Level 8
For Question 1 and 2 :- If you are Cisco partner you  can open case at cisco.com/go/ph . PH team will be able to help you with  the costing and ordering.
For Question 3 :- If you  are Cisco UC certified partner You can open case at  cisco.com/go/pdihelpdesk. PDI team will be able to help you on that.
Ronak Patel
Rate all helpful post by clicking stars below the answer.
Regards Ronak Patel Rate all helpful post by clicking stars below the answer.
