Upgrate CUCM 5.1.3(a) to 8.6
Emin Aliyev
I`m upgrating cucm 5.1.3(a) to 7.1.3.3000-1 and then to 8.6.
I`m install my cucm on ESXi,while upgrating 5.1.3 to 7.1.3 i get error that
Errors encountered.
The directory was located and searched but no valid options or upgrades were available. Note, a machine cannot be downgraded so option and upgrade files for previous releases were ignored.
in upgrate matrix i can do  bridge upgrate to 7.1.3
If you are running 5.1(3e) now
You must install COP File ciscocm.513e_upgrade.cop.sgn before you perform this upgrade
17 Replies 17
s.angelmahr
Have you done a reboot of the server lately? I once had a problem with strange upgrade behavior when the server was running for some time. May be worth a try.
Sven
I have done,but it doesn`t help me
bernhardczapp
Level 4
Level 4
What type of file do you have?
CUCM 5 uses tar.gz.sgn files.
Starting with CUCM 6 it used the sgn.iso files.
When Upgrading from 5 you get this specific file, it can't be downloaded from cisco.
Using a original DVD should also work.
Edit:
Coorected CUCM 6 file extension
now i try to switch version to 3(e) then download speciall cop file for upgrate and then using iso file to upgrate to 7 version.
Sorry I was wrong.
You can download the files from CCO
The filename is something like cisco-ipt-k9-patch7.1.XXX.sgn.zip.
thanks i try to do it
Just wanted to mention that you get that when:
a) no valid upgrade files are found
b) you're pointint to the wrong TFTP path, and there's actually no upgrade files.
And the upgrade file names should be something like this:
UCSInstall_UCOS_7.1.5.35900-7.sgn.iso
java
if this helps, please rate
www.cisco.com/go/pdihelpdesk
java
I try to upgrate 7.1.3.3000-1.sgn.iso,but fail.
Unfortunately Jamies information was wrong. And as I said earlier you must not use the sgn.iso files.
If you take a look at the cco download page you will find files like:
7.1(5b)su6 US Export Restricted - full encryption capabilities (non-bootable) - For upgrade from 5.1(x). Upgrades from 5.1(x) need to be requested via PUT (www.cisco.com/upgrade) or purchased to obtain necessary licenses.
cisco-ipt-k9-patch7.1.5.35900-7.sgn.zip
You have to use this kind of files to upgrade cucm 5.1!!!
Unzip them and you should find a tar.gz.sgn file.
These files are not available for every version of 7.1.
Try 7.1(5b)SU6 this version should work according to the compatibility matrix.
i try   to upgrate my 5.1.3(a) to (e) but  get error that authentication failed md5 checksum.But i download from cisco file  is same aa it mention
Are you using SFTP or FTP?
Try the other one, some Versions of 5 had problems with file transfer.
today i will try file
I try to use both ftp and stftp
i try to install this file  but cucm don`t see it.
as you say i unzip  this file and find
cisco-ipt-k9-patch7.1.5.34900-7.tar.gz.sha1.sgn
