02-20-2019 02:26 AM
Urgent : after enabling SAML SSO .. i am not able to login any cm servers wihth any account
please advice how to roll back or disable the SMAL SSO to be able to login again using local admin
Solved! Go to Solution.
02-20-2019 03:03 AM
You can try to connect CUCM Publisher via CLI and issue the following command:
This command disables single sign on.
This command displays the status and configuration parameters of single sign on.
than try to login again.
if this helps, please rate.
02-20-2019 02:57 AM
TRY the recovery URL, as per
i have never used it myself, but this is the publiscised method to bypass SSO
02-20-2019 03:03 AM
