Urgent : after enabling SAML SSO .. i am not able to login any cm servers
networkexpert
Urgent : after enabling SAML SSO .. i am not able to login any cm servers wihth any account
please advice how to roll back or disable the SMAL SSO to  be able to login again using local admin
Daniov1
You can try to connect CUCM Publisher via CLI and issue the following command:
utils sso disable
This command disables single sign on.
utils sso status
This command displays the status and configuration parameters of single sign on.
than try to login again.
if this helps, please rate.
Dennis Mink
TRY the recovery URL, as per
https://www.cisco.com/c/en/us/support/docs/unified-communications/unified-communications-manager-version-105/118770-configure-cucm-00.html
i have never used it myself, but this is the publiscised method to bypass SSO
Please remember to rate useful posts, by clicking on the stars below.
Daniov1
utils sso disable
utils sso status
