11-21-2018 02:46 AM - edited 03-17-2019 01:45 PM
I'm curious to find out why the below call fails, this is whats configured:
TP rule:
Pattern: !
CSS: Mobile_Test
Urgent Priority: CHECKED
IP-Phone-1: 4012 (UCCX_Agent) (UCCX_Agent_xTranslate)
IP-Phone-2: 4017 (UCCX_Agent) (UCCX_Agent_xTranslate)
CSS-Agent:
UCCX_Agent
IP-Phone-1 dials IP-Phone-2 "401" before he finishes, he gets a reorder tone.
After some checking I found the only reason he can dial 401 to being with is that TP CSS has access to other DN's with starting DN "40" but not to 4017.
Urgent Priority is some to only avoid T302 when there is a mutliple matches and not to force routing. Also when Urgent Priority is checked on the 4017 DN, same thing happens.
Currently I avoid matching by using 0! instead of !.
Can someone tell me why this is?
Logs are attached.
Solved! Go to Solution.
11-21-2018 07:37 AM
I don't think you're going to see any sort of sensible behaviour marking a variable length pattern as Urgent. Urgent is supposed to be used on fixed length patterns, to make sure they're matched and routed without waiting for further digits. I just don't see how that can be expected to work with a variable length, which inherently relies on timeout or explicit unblock dialling.
11-21-2018 03:16 AM
You could try sticking in the DNA and see what it matching
11-21-2018 03:19 AM
I already did it matches and the call work also i enter the number full before i dial it works, this problem happens when dialing number by number.
En block dialing on other phones works.
11-21-2018 03:53 AM
What are you trying to achieve with the "!" pattern that's marked as urgent? That seems contradictory as "!" means any number of digits terminated by timeout or explicit dial command, so I would expect that making that urgent would immediately match the first digit dialled.
11-21-2018 04:58 AM
11-21-2018 03:51 AM
If you’re attempting a PLAR, the behavior differs depending on whether you’re using SCCP or SIP phones. If the latter you also need to configure a SIP Dial Rule.
The other thing that sounds strange here is your statement that the TP CSS has access to other patterns. CUCM won’t accept user input after matching a TP. You can’t dial beyond it, so to speak. Whatever digit string matched the TP, unless you transform it on the TP, is what used by digit analysis from there. If you have “0!” marked urgent then you will match the TP and begin digit analysis after the second digit is entered, i.e. “0[0-9]”. In CUCM the exclamation point matches one or more digits, similar to Unix \d+
11-21-2018 07:30 AM
I'm using the calling party transformation mask set to: 5000
0! TP, matches with outgoing RP with the access code 0.
I'm confused as there is no DN or TP/RP being with "401"
"CUCM won’t accept user input after matching a TP."
I cant find what is matching, as it doesn't have access to Partition with access to DN in the 410X Range.
11-21-2018 07:37 AM
11-21-2018 07:57 AM
even when its not marked urgent it matches, i also tried the 4XXX TP with and without the urgent priority and it was still matching TP which has 1000 options instead of the 4017 DN which is only 1 Option. CUCM uses closest-match logic for call routing, and as far as I remember the if a DN is created register or otherwise it be considered a potential match the same as TP or RP.
11-21-2018 09:32 AM
Which partitions are the various patterns and DNs in, and what do the CSSs of the phones contain? Difficult to comment on any call routing issue without knowing that detail. Although the fact that DNA thinks it works suggests it's a timeout vs urgent issue, as DNA simulates enblock rather than digit by digit dialling.
11-21-2018 09:55 AM
TP rule:
Pattern: 4XXX
CSS: UCCX_Agent
IP-Phone-1: 4012
IP-Phone-2: 4017
Line PT: UCCX_Agent
Line CSS: UCCX_Agent
UCCX_Agent:(CSS)
UCCX_Agent
IP-Phone-3: 4020
Line PT: Internal_PT
Line CSS: Mobile_CSS
Mobile_CSS:
Internal_PT
Mobile_CSS
UCCX_Agent
11-21-2018 09:58 AM - edited 11-21-2018 09:59 AM
What partition is the TP 4XXX in?
And the device CSSs on the phones?
11-21-2018 10:00 AM
TP PT: UCCX_Agent_xTranslate
Device CSS: None (For all ip-phones)
11-21-2018 10:20 PM
it works, I'm looking for ghosts.
