url service XML don´t work after ugrade firmware to 11-0-6SR2-4
marportela
Hello, currently I have SIP phones 8821 with firmware: 11-0-5SR3-2 and url services works properly , but I upgraded phones to firmware: 11-0-6SR2-4 and all works except url service: in phone appear when I click in: Aplications->CME Services URLs : error XML [4]
I have a C3925-CME-SRST/K9 , ver: Cisco IOS Software, C3900 Software (C3900-UNIVERSALK9-M), Version 15.6(3)M1, RELEASE SOFTWARE (fc2)
Config relate in CME:
voice register global
url service http://10.173.62.251/Cisco/Main.xml
Main.xml file I´m using:
<CiscoIPPhoneMenu>
<Prompt>PO</Prompt>
<MenuItem>
<Name>Conferencias TEAMS</Name>
<URL>http://10.173.62.251/Cisco/Cfg.xml</URL>
</MenuItem>
</CiscoIPPhoneMenu>
Thanks in advance
Thanks Nithin , at last I tried with version 11-0-6SR1-4 , and works fine.
Does the issue resolve if you downgrade back to 11.0(5)? If so, it absolutely sounds like you hit a bug. I didn't see a good match in the Bug Search Tool , but it could be I just didn't find it or that no one has reported it yet. If the downgrade resolves the issue, I'd suggest contacting TAC and letting them know. If it's a known thing, they may have a workaround.
Maren
Thanks Maren , in fact I downgroade the firmware to recover functionality and works fine , today I copied files again to CME and I repeated upgrade , but the same result
never happened me.
Could be a BUG, better to stay with your old working firmware versions.
Note:- 3925 is getting EOL this year.
Response Signature
