User cannot connect on phone with extension mobility
kseewald
Dear experts,
we have IP Communicator with Extension mobility. Application Login/logout is working fine.
User can Login with his Profile on any Workstation.
only one PC with IP Communicator brings error when loggin in "Login ist nicht verfügbar (11)"  (it´s german - Translation is "Login is not available (11)"
it happens with any user account.
when typing in an unknown accout we get back the message "Login erneut versuchen (201)"  - " Login try again (201)" .
The link the phone is trying to reach is same like from any Communicator which is working fine.
http://10.10.60.100:8080/emapp/EMAppServlet?device=SEP64006a836bd6&seq=1234&userid=testwd
we did two  wireshark from a Comm where the Login is fine and the one which is not fine.
I can´t figure out of these, where the Problem Comes from  (see attached files)
Need help
Best Regards,
Klaus
Jonathan Schulenberg
Extension Mobility is not enabled on that CIPC device. This is a checkbox on the Device Configuration page.
Hi, The Checkbox was definitely set .
Do you have Web Proxy configured on the PC where the non-working CIPC is? Try bypassing CUCM IP Address/LAN IP Address
