12-20-2016 08:17 AM - edited 03-17-2019 09:00 AM
There is a user whenever she tries to create a new pin, she is receiving invalid pin message
These options are selected in password setting :
1. User Must Change at Next Sign-In
Please advise what can be the reasons for not being able to change VM PIN and what can I do to enable her to change the Pin.
Cisco Unity Connection version: 11.0.1.22040-1
12-20-2016 08:25 AM
Have you checked the authentication rule for this user. Is the rule checking for trivial passwords?
Brandon
12-20-2016 08:33 AM
Yes, Brandon.
I have checked the authentication rule and Check for Trivial Passwords is checked already.
12-20-2016 09:09 AM
Do you have the option to store x number of credentials and do not allow them to be used again?
12-20-2016 10:03 AM
If you have check for trivial passwords checked make sure the user is using a PIN that meets the complexity requirements:
A non-trivial phone PIN has the following attributes:
