User is not able to change voicemail pin
There is a user whenever she tries to create a new pin, she is receiving invalid pin message
These options are selected in password setting :
1. User Must Change at Next Sign-In
Please advise what can be the reasons for not being able to change VM PIN and what can I do to enable her to change the Pin.
Cisco Unity Connection version: 11.0.1.22040-1
Brandon Buffin
Have you checked the authentication rule for this user. Is the rule checking for trivial passwords?
Brandon
Yes, Brandon.
I have checked the authentication rule and Check for Trivial Passwords is checked already.
Do you have the option to store x number of credentials and do not allow them to be used again?
java
if this helps, please rate
If you have check for trivial passwords checked make sure the user is using a PIN that meets the complexity requirements:
A non-trivial phone PIN has the following attributes:
  • The PIN cannot match the numeric representation of the first or last name of the user.
  • The PIN cannot contain the primary extension or alternate extensions of the user.
  • The PIN cannot contain the reverse of the primary extension or alternate extensions of the user.
  • The PIN cannot contain groups of repeated digits, such as “408408” or “123123.”
  • The PIN cannot contain only two different digits, such as “121212.”
  • A digit cannot be used more than two times consecutively (for example, “28883”).
  • The PIN cannot be an ascending or descending group of digits (for example, “012345” or “987654”).
  • The PIN cannot contain a group of numbers that are dialed in a straight line on the keypad when the group of digits equals the minimum credential length that is allowed (for example, if 3 digits is allowed, the user could not use “123,” “456,” or “789” as a PIN).
