03-20-2018 01:53 PM - edited 03-17-2019 12:27 PM
I have several users in my organization that have had gotten married and changed their names, i have updated their names in my AD/exchange and how would like to update their name in the cisco phone systems, how would i go about this without breaking their current phones and voicemails boxes, we use CUCM and Cisco unity connection for our voicemail
03-20-2018 02:16 PM
On CUCM if you mean the display/alerting name or similar setting, just go and change it, that's all there is to it.
03-20-2018 03:07 PM
If you are just changing their last names, then no problem, LDAP synch on cucm and cuc, will automatically reflect their surname, If you are changing their user ID as well. I am pretty sure that will break things as the UID cannot be cahnged on the fly on cucm/cuc but only in AD, IF you are using LDAP schemes to sync users.
03-21-2018 05:58 AM
I dont believe we are using LDAP for the names, i have already changed their names in AD/exchange and they havnt not changed on the phones, and i believe we create each user manually in CUCM.
03-21-2018 06:24 AM
You can also try to update lines through Bulk by exporting lines and importing them back. Working on a spreadsheet could be easier than going phone by phone to change lines appearance.
Regard
Carlo
