10-17-2016 05:07 PM - edited 03-17-2019 08:23 AM
Can an 8851 or 8861 phone be connected to two switches (PVST running on switches) to supply redundancy to the end-point device. Using CUCM 11.5. No Computer connectivity needed.
See Attached Diagram
10-17-2016 06:25 PM
No, there's no way to do that. You can only have one cable from the switch to the phone. The internal switch is not meant to do any of that.
10-17-2016 09:17 PM
To add to Jaimie's response, the phone has two ports. One of them is PoE. So how is the 2nd one be "redundancy" if one is NOT PoE?
