Using both switch ports on a Cisco 8851 and/or 8861 phone for redundancy
gcopeland
Can an 8851 or 8861 phone be connected to two switches (PVST running on switches) to supply redundancy to the end-point device.  Using CUCM 11.5.  No Computer connectivity needed.
See Attached Diagram
Jaime Valencia
No, there's no way to do that. You can only have one cable from the switch to the phone. The internal switch is not meant to do any of that.
java
if this helps, please rate
Leo Laohoo
To add to Jaimie's response, the phone has two ports.  One of them is PoE.  So how is the 2nd one be "redundancy" if one is NOT PoE?
