Using remote CME to make PSTN calls
Im a tring to setup the dial-peers on both my CME to send PSTN traffic from CME A who has the IP phones, and CME B who has the POTS.
How can I setup dial-peer in A and B ?
Thank you
Anas Abueideh
Level 9
Level 9
you need to configure voip dial-peer between CME A and B. let us assume your extensions are 2XX, and your ip addresses are 10.100.10.1 for CME A , 10.100.11.1 for CME B
CME-A config
dial-peer voice 100 voip
  incoming called-number .
destination-pattern .T
session target ipv4:10.100.11.1
dtmf-relay h245-alphanumeric h245-signal
no vad
CME-B Config
destinatin-pattern 2..$
session target ipv4:10.100.10.1
no vad
Anas
please rate if it is helpful
5 Replies 5
Anas Abueideh
Level 9
Level 9
CME-A config
no vad
CME-B Config
no vad
Anas
I copy /paste your config in both my CME routers and it works great. - Thank you.
I have not seen these commands yet, not sure they are part of the CCNA UC curriculum. Can you explain call flow ?
I will review the commands and try to make the match. Thanks again !
Just testing, DTMF tones are not going thru from Router A (from 7961 IP phones and CIPC), but OK from Router B (router with the POTS)
Will keep looking.....
try to configure transcoder on router B and check if it is working.
thanks for the rating
Anas
And how would that go ?
The DTMF are working OK when the call is made from Router B, it is only when I make the calls from Router A using ephones tandeming to Router B that the DTMF tones are'nt going thru.
