Hunt group Problems
phoenix3195
Hi Guys,
I have a very strange problem:
I have hunt group configured on Call Manager express 7.0.1 and the configuration is as the followings:
ephone-hunt 3 longest-idle
pilot 3001
list 1120,1130, 1141
Whenever there is no agent available (not available means his or her phone is not registered with CME at all), the CME uses a dialpeer pointing to an FXO port and dials 3001 and use the fxo port and it keeps it busy even if there is no one calling the hunt group anymore.
islam.kamal
Level 10
Level 10
Dear
Can you share the configuration ,thank you
Chris Deren
How did you figure it is doing that?  Did you run any call debugs? Can you share those?
Chris
