Dear All,
I am running virtual CME (12.6) and Virtual CUE (10.5) in a lab environment (both using evaluation license). I tried both SCCP and SIP CME configuration. I could not create web admin user and the telephony-service or voice register pool. Also failed to run the initialization wizard. Is there any good document or blog which can help me setting up this?
Thank You
Is CME installed and configured? Is CUE installed? Are you able to get to the CUE web interface? What errors are you receiving?
https://www.cisco.com/c/en/us/td/docs/voice_ip_comm/unity_exp/rel10_0/install/cue_install_book.html
Brandon
In CME 12.6, the web admin and related commands were deprecated.
Unified CME Graphical User Interface Deprecation
The CME and CUE systems can still be integrated using the standard integration documentation, but I have yet to find any document explaining how to re-enable the synchronization feature.
Maren
