VG202 voice gateway alternative ?
Dear Experts
                    Is there any way to connect analog phone without using Cisco VG202 or any other Cisco device.....as a VG 202 will connect only two(2) phnes, hence it becomes vey costly for juz connecting two phones.
Regard Nitesh
8 Replies 8
Ayodeji Okanlawon
It depends on how many ports you need/want. Other options are VG204, ATA187 or vic2-2fxo, vic2-4fxo ports
Please rate all useful posts
"opportunity is a haughty goddess who waste no time with those who are unprepared"
aokanlawon thnx.............
                              Isnt dere any cheap n best way to itegrate analog fone....as all this cost a lot......in comparison to using an basic ip phone...main purpose is FAX running which only works on analog signal
I am afraid those are all the options that you have. You can switch to IP based fax like right fax as an alternative.
ATAs are a lot cheaper than VGs.
GTG
Please rate all helpful posts.
analog telephony adapter rite ????????????/
Can u tell me few companies of ATA
whats main difference between Cisco SPA112 and VG202
All the VG gateways are IOS based devices: Easy to manage, but you pay for it.
All the Cisco ATAs are based on a third party chipset, and configuration is...*sigh*.
GTG
A certain company called "Cisco" makes a two line ATA:
http://www.cisco.com/en/US/prod/collateral/voicesw/ps6788/phones/ps514/ps11026/data_sheet_c78-608596.html
The ATA 187 is about a quarter of the price of the VG202.
GTG
