VG204 Installation?
victoriabardy
Level 4
Level 4
Hello all,
I have my first VG 204 analog gateway to install this weekend and the equipment is already on site so I will be working on it once I get there.  I have configured a VG248 and a VG224 and they both were different in the initial configuration.  Does anyone here on the forum have any experience with the VG204?  Is it just consoling in and doing the initial CLI IP configuration?
Any feedback would be great.
Thank you.
Rgds,
Vicky
Leonardo Santana
Hello Vicky,
The VG204 CLI is similar to an router or switch CLI, take a look on this doc, is very easy:
http://www.cisco.com/en/US/docs/routers/access/vg202_vg204/software/vg2_vg4_conf_ps2250_TSD_Products_Configuration_Guide_Chapter.html
http://www.cisco.com/en/US/docs/routers/access/vg202_vg204/software/vg2_vg4_voip_ps2250_TSD_Products_Configuration_Guide_Chapter.html
Please rate this if helps you!
Leonardo Santana
Leonardo Santana
*** Rate All Helpful Responses***
If you configured VG224 before these are no different and the same logic/syntax applies. Vg248 was completly differnt as it did not use IOS.
HTH,
Chris
