VG204XM not registering
san.carlos
Having an issue getting a VG204XM gateway to register with CUCM. Status on VG204XM shows error with downloading configuration file. Is this a compatibility issue, where the VG204XM is not supported by the version of CUCM? Please advise.
VG204XM IOS version 15.4(3)M1
CUCM 8.5.1
VG204XM CCM-Manager Status:
Priority        Status                   Host
Primary         Registering with CM      10.41.0.6
First Backup    Backup Ready             10.18.0.5
Second Backup   None
Current active Call Manager:    None
Backhaul/Redundant link port:   2428
Failover Interval:              30 seconds
Keepalive Interval:             15 seconds
Last keepalive sent:            17:21:30 UTC Aug 24 2015 (elapsed time: 00:18:05)
Last MGCP traffic time:         17:39:07 UTC Aug 24 2015 (elapsed time: 00:00:28)
Last failover time:             17:38:37 UTC Aug 24 2015 from (10.41.0.6)
Last switchback time:           17:39:07 UTC Aug 24 2015 from (10.18.0.5)
Switchback mode:                Graceful
MGCP Fallback mode:             Enabled/ON
Last MGCP Fallback start time:  17:32:48 UTC Aug 24 2015
Last MGCP Fallback end time:    None
MGCP Download Tones:            Disabled
TFTP retry count to shut Ports: 2
FAX mode: cisco
Configuration Error History:
TFTP File download failed
VG204XM Config:
Building configuration...
Current configuration : 1391 bytes
! Last configuration change at 17:59:55 UTC Sun Mar 3 2002
version 15.4
no service pad
hostname Router
boot-start-marker
boot-end-marker
no aaa new-model
ip cef
no ipv6 cef
voice-card 0
interface FastEthernet0/0
 ip address 10.18.0.18 255.255.240.0
 duplex auto
 speed auto
interface FastEthernet0/1
 no ip address
 shutdown
 duplex auto
 speed auto
ip forward-protocol nd
no ip http server
ip route 0.0.0.0 0.0.0.0 10.18.0.1
control-plane
voice-port 0/0
voice-port 0/1
voice-port 0/2
voice-port 0/3
mgcp
mgcp call-agent 10.41.0.6 2427 service-type mgcp version 0.1
mgcp bind control source-interface FastEthernet0/0
mgcp bind media source-interface FastEthernet0/0
mgcp behavior rsip-range tgcp-only
mgcp behavior comedia-role none
mgcp behavior comedia-check-media-src disable
mgcp behavior comedia-sdp-force disable
mgcp profile default
sccp local FastEthernet0/0
ccm-manager music-on-hold
ccm-manager fallback-mgcp
ccm-manager redundant-host 10.18.0.5
ccm-manager mgcp
ccm-manager config server 10.18.0.5
ccm-manager config
ccm-manager sccp local FastEthernet0/0
line con 0
 no modem enable
line aux 0
line vty 0 4
 login
 transport input none
ntp server 172.17.0.1
end
Nadeem Ahmed
As per the Compatibility matrix it show 15.1, however can you please try restarting the tftp service and do no ccm-manager and ccm-manager
http://www.cisco.com/c/en/us/td/docs/voice_ip_comm/uc_system/unified/communications/system/versions/IPTMtrix.html#wp10167
Br, Nadeem Please rate all useful post.
I restarted the TFTP server and executed the no ccm-manager and ccm-manager command, but the results are still the same. The gateway doe snot register. I didn't find any software releases for the VG204XM that go back to version 15.1 on the downloads page.
Jonathan Schulenberg
The data sheet shows that the VG204 is supported by 6.1.3, 7.0.1 or later. Additionally, if you see it as an option to add under Device > Gateway it is supported by that CUCM release.
What does the CUCM config look like? Does the Domain Name match the FQDN configured on the VG? Is the Module in Slot 0 configured?
