VG224 bulk edit option
hello I have 280 VG224's fully populated, i need to change partition on the extensions configured on the FXS ports
all the VGs are setup as MGCP
we have ucm 7.1.3 and ucm 8.6
please let us know if you know  a way to bulk edit all those extensions
thank you
Cris
Aaron Harrison
Not a 'standard' way.
I think you may be able to use the import/export functions to export 'gateways', edit the file and then re-import it on your 8.x cluster.
Aaron
Aaron Please remember to rate helpful posts to identify useful responses, and mark 'Answered' if appropriate!
