06-05-2015 09:26 AM - edited 03-17-2019 03:14 AM
I have some debit/credit machines that I want to move off PSTN's and onto Cisco analogs so is there a way to insert a 9 ( access code ) as soon as the port goes off hook. This is a trial, but I do not want to modify the debit/credit machines.
Norm
06-05-2015 09:50 AM
What protocol will you use???
06-05-2015 10:04 AM
SCCP
06-05-2015 10:21 AM
You'd need to configure a translation pattern in CUCM to add that 9
06-09-2015 07:15 AM
Or create new dial patterns in a new partition assigned to a CSS that is assigned to only the VG224 analog ports. Make the dial patterns the same as the existing ones but leave off the 9.
06-10-2015 12:26 AM
You didn't specify what is your control server. For discussion sake, I will assume CME as other guys already posted a solution for CUCM.
Create a voice translation on the CME, config is as follows.
voice translation-rule 2
rule 1 // /9&/
voice translation-profile Prefix-Nine-EFTPOS
translate called 2
ephone-dn 30 dual-line
number 8889
description EFTPOS
name EFTPOS
translation-profile incoming Prefix-Nine-EFTPOS
When the EFTPOS terminal dials, the CME will prefix 9 automatically.
The rest of VG224 and CME SCCP integration configuration can be found here:
http://www.cisco.com/c/en/us/support/docs/voice-unified-communications/vg224-voice-gateway/115021-vg224-voice-gateway-sccp-00.html
