VG224 - MAXIMUM DISTANCE
alicia.vega
Is it any problem in connecting an analog phone to a VG224 with a 2,5 kilometres cable?
Thank you very much!
Imran Khan R
FXS Analog Voice Port Maximum Distance:-
The maximum distance is established by a total allowable loop resistance, including the phone or terminal equipment, of 600 ohms.  Our FXS interface meets OPS Class B specs. Specifically, we can source greater than 20ma to a resistive distance of up to 1100 ohms. The homework question is translating impedance to actual distance in meters in your customer's environment; which will depend on the gauge of the wire as well as how the wire is routed and punched-down. It will depend on the type of phone/equipment you are hooking on the line as well as to how well it will work.
Also found how to calculate the dc loop resistance:-
Calculating dc loop resistance
LRi = CRi * SLi
where LRi= DC loop resistance for cable section
CRi= Conductor Resistance per unit length for the cable section ( used gauge 24 rj11 cable)
Sli= length of cable section
Lri =600ohms
CRi = 173 ohm/loopkm
SLi = ?
= 600 ohm/ 173 ohm/loopkm
= (600 / 173 ) loop KM
= 3.47KM
= 3470 * 3
= 11384 feet.
So the FXS on the VG 224 using a gauge 24 cable (RJ-11) would allow for a max loop distance of 10410 feet .
rshaltie
In your calculation, the maximum distance is established by a total allowable loop resistance should be NOT including the phone or terminal equipment.
so the 600 ohms in total - 430 ohms of the phone = 170 ohm for line resistance
= (170 / 173 ) loop KM
=0.98 Km
Alicia,
Looking at the VG224 datasheet
http://www.cisco.com/en/US/prod/collateral/voicesw/ps6790/gatecont/ps2250/ps5516/product_data_sheet09186a00801d87f6.html
Category
112-FXS Bundle
VG 224
VG 204/VG 202
FXS Loop Length
3000 ft, 26 AWG
3000 ft, 26 AWG
3000 ft, 26 AWG
You should will be out of reach at 2.5 KM
3000 feet is approx 1KM
Alex.
Please rate useful posts.
Regards, Alex. Please rate useful posts.
