VG224 MOH support
Chris Deren
Looking at CUCM SRND Table "Cisco Analog Gateway Features” indicates that MOH is not supported on VG224. Can anyone confirm that this is true for unicast and multicast MOH?
Chris
2 Accepted Solutions
Udit Mehrotra
Chris,
MoH on SCCP VG224 is not supported. It is supported with H323/SIP/MGCP as per following -
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/srnd/7x/moh.html#wp1043577
Udit
Chris,
Unicast with SCCP will work.
MCast won't work because of  -
http://tools.cisco.com/Support/BugToolKit/search/getBugDetails.do?method=fetchBugDetails&bugId=CSCsb60015
The above bug is not the reason but just a confirmation tha MCast is not supported.
Udit
5 Replies 5
Udit Mehrotra
Chris,
Udit
Yeah, I saw that, but since it lists both unicast/multicat support I was not sure if this was the case for either one or both.
Chris
I can say that for sure that Multicast is not supported with SCCP. Let me confirm about Unicast.
Udit
Chris,
Udit
Thanks.
Chris
