Can someone advise me where the cause of the registration issue can possibly lies? We have Cisco VG224 which has the IP connectivity with CUCM 6 (also in the same Vlan). I get the following on show ccm-manager.
voip-010#sh ccm-manager
MGCP Domain Name: voip-010.corporateict.domain
Priority Status Host
Primary Registering with CM 10.10.1.50
First Backup Backup Ready 10.101.20.50
Second Backup None
Current active Call Manager: None
Backhaul/Redundant link port: 2428
Failover Interval: 30 seconds
Keepalive Interval: 15 seconds
Last keepalive sent: 05:41:04 UTC May 13 2011 (elapsed time: 4d02h)
Last MGCP traffic time: 08:35:48 UTC May 17 2011 (elapsed time: 00:00:20)
Last failover time: 08:35:18 UTC May 17 2011 from (10.10.1.50)
Last switchback time: 08:35:48 UTC May 17 2011 from (10.101.20.50)
Switchback mode: Graceful
MGCP Fallback mode: Not Selected
Last MGCP Fallback start time: None
Last MGCP Fallback end time: None
MGCP Download Tones: Disabled
TFTP retry count to shut Ports: 2
Configuration Auto-Download Information
No configurations downloaded
Current state: Waiting for commands
Configuration Download statistics:
Download Attempted : 1
Download Successful : 0
Download Failed : 1
TFTP Download Failed : 0
Configuration Attempted : 0
Configuration Successful : 0
Configuration Failed(Parsing): 0
Configuration Failed(config) : 0
Last config download command:
Configuration Error History:
TFTP File download failed
FAX mode: disable
TFTP service on CUCM is confirmed to be running but I am getting failed as shown in the output. Following is an extract of MGCP configuration in VG224:
hostname voip-010
ip domain name corporateict.domain
interface FastEthernet0/0
ip address 10.10.1.57 255.255.255.0
duplex auto
speed auto
ip default-gateway 10.10.1.1
ip route 0.0.0.0 0.0.0.0 10.10.1.1
voice-port 2/0
cptone AU
voice-port 2/1
cptone AU
voice-port 2/23
cptone AU
ccm-manager redundant-host 10.101.20.50
ccm-manager mgcp
no ccm-manager fax protocol cisco
ccm-manager music-on-hold
ccm-manager config server 10.10.1.50
ccm-manager config
mgcp
mgcp call-agent 10.10.1.50 service-type mgcp version 0.1
mgcp dtmf-relay voip codec all mode out-of-band
mgcp rtp unreachable timeout 1000 action notify
mgcp modem passthrough voip mode nse
mgcp package-capability rtp-package
mgcp package-capability sst-package
no mgcp package-capability res-package
no mgcp package-capability fxr-package
no mgcp timer receive-rtcp
mgcp sdp simple
mgcp fax t38 inhibit
mgcp rtp payload-type g726r16 static
mgcp bind control source-interface FastEthernet0/0
mgcp bind media source-interface FastEthernet0/0
mgcp profile default
dial-peer voice 1 pots
service mgcpapp
incoming called-number .
port 2/0
dial-peer voice 2 pots
service mgcpapp
port 2/1
dial-peer voice 24 pots
service mgcpapp
port 2/23
Thanks much in advance for your contribution.
Best regards,
Lay
You should use SCCP, not MGCP to control a VG224 from CUCM.
Hi Lay,
MGCP Gateway registration problems are often related to Domain Name issues
http://www.cisco.com/en/US/products/sw/voicesw/ps556/products_tech_note09186a00805a316c.shtml
Cheers!
Rob
Thanks Guys for your replies. Rob, I have tried restarting mgcp in VG224 and re-configuring domain name to ensure it matches with the one in CUCM. I have also restarted TFTP service in CUCM but still no difference.
no mgcp
mgcp
hostname voip-010
I have turned on "debug mgcp packet" and got the followings:
voip-010#debug mgcp packet
Media Gateway Control Protocol packet debugging for all end points is on
voip-010#
May 18 08:54:18.710: MGCP Packet sent to 10.10.1.50:2427--->
RSIP 30552318 *@voip-010.corporateict.domain MGCP 0.1
RM: graceful
May 18 08:54:18.714: MGCP Packet sent to 10.101.20.50:2427--->
RSIP 30552320 *@voip-010.corporateict.domain MGCP 0.1
RM: restart
May 18 08:54:18.714: MGCP Packet received from 10.10.1.50:2427--->
200 30552318
May 18 08:54:18.714: [S] mgcp_msg_ack:6152,Updating (*)=10.10.1.50
May 18 08:54:18.714: *:NO-MATCH, 10.101.20.50:2427, 10.10.1.50:2427
May 18 08:54:18.714: aaln/S*/*:NO-MATCH, 10.101.20.50:2427, 10.10.1.50:2427
May 18 08:54:18.714: aaln/S2/*:NO-MATCH, 10.101.20.50:2427, 10.10.1.50:2427
May 18 08:54:18.714: aaln/S2/0:NO-MATCH, 10.101.20.50:2427, 10.10.1.50:2427
May 18 08:54:18.718: aaln/S2/1:NO-MATCH, 10.101.20.50:2427, 10.10.1.50:2427
May 18 08:54:18.718: aaln/S2/2:NO-MATCH, 10.101.20.50:2427, 10.10.1.50:2427
May 18 08:54:18.718: aaln/S2/3:NO-MATCH, 10.101.20.50:2427, 10.10.1.50:2427
May 18 08:54:18.718: aaln/S2/4:NO-MATCH, 10.101.20.50:2427, 10.10.1.50:2427
May 18 08:54:18.718: aaln/S2/5:NO-MATCH, 10.101.20.50:2427, 10.10.1.50:2427
May 18 08:54:18.718: aaln/S2/6:NO-MATCH, 10.101.20.50:2427, 10.10.1.50:2427
May 18 08:54:18.718: aaln/S2/7:NO-MATCH, 10.101.20.50:2427, 10.10.1.50:2427
May 18 08:54:18.718: aaln/S2/8:NO-MATCH, 10.101.20.50:2427, 10.10.1.50:2427
May 18 08:54:18.718: aaln/S2/9:NO-MATCH, 10.101.20.50:2427, 10.10.1.50:2427
May 18 08:54:18.718: aaln/S2/10:NO-MATCH, 10.101.20.50:2427, 10.10.1.50:2427
May 18 08:54:18.718: aaln/S2/11:NO-MATCH, 10.101.20.50:2427, 10.10.1.50:2427
May 18 08:54:18.718: aaln/S2/12:NO-MATCH, 10.101.20.50:2427, 10.10.1.50:2427
May 18 08:54:18.718: aaln/S2/13:NO-MATCH, 10.101.20.50:2427, 10.10.1.50:2427
May 18 08:54:18.718: aaln/S2/14:NO-MATCH, 10.101.20.50:2427, 10.10.1.50:2427
May 18 08:54:18.718: aaln/S2/15:NO-MATCH, 10.101.20.50:2427, 10.10.1.50:2427
May 18 08:54:18.718: aaln/S2/16:NO-MATCH, 10.101.20.50:2427, 10.10.1.50:2427
May 18 08:54:18.718: aaln/S2/17:NO-MATCH, 10.101.20.50:2427, 10.10.1.50:2427
May 18 08:54:18.718: aaln/S2/18:NO-MATCH, 10.101.20.50:2427, 10.10.1.50:2427
May 18 08:54:18.718: aaln/S2/19:NO-MATCH, 10.101.20.50:2427, 10.10.1.50:2427
May 18 08:54:18.718: aaln/S2/20:NO-MATCH, 10.101.20.50:2427, 10.10.1.50:2427
May 18 08:54:18.718: aaln/S2/21:NO-MATCH, 10.101.20.50:2427, 10.10.1.50:2427
May 18 08:54:18.718: aaln/S2/22:NO-MATCH, 10.101.20.50:2427, 10.10.1.50:2427
May 18 08:54:18.718: aaln/S2/23:NO-MATCH, 10.101.20.50:2427, 10.10.1.50:2427
May 18 08:54:18.762: MGCP Packet received from 10.101.20.50:2427--->
500 30552320
May 18 08:54:48.710: MGCP Packet sent to 10.101.20.50:2427--->
RSIP 30552322 *@voip-010.corporateict.domain MGCP 0.1
RM: forced
May 18 08:54:48.714: MGCP Packet sent to 10.10.1.50:2427--->
RSIP 30552324 *@voip-010.corporateict.domain MGCP 0.1
RM: restart
May 18 08:54:48.714: MGCP Packet received from 10.101.20.50:2427--->
200 30552322
May 18 08:54:48.714: [S] mgcp_msg_ack:6152,Updating (*)=10.101.20.50
May 18 08:54:48.714: *:NO-MATCH, 10.10.1.50:2427, 10.101.20.50:2427
May 18 08:54:48.714: aaln/S*/*:NO-MATCH, 10.10.1.50:2427, 10.101.20.50:2427
May 18 08:54:48.718: aaln/S2/*:NO-MATCH, 10.10.1.50:2427, 10.101.20.50:2427
May 18 08:54:48.718: aaln/S2/0:NO-MATCH, 10.10.1.50:2427, 10.101.20.50:2427
May 18 08:54:48.718: aaln/S2/1:NO-MATCH, 10.10.1.50:2427, 10.101.20.50:2427
May 18 08:54:48.718: aaln/S2/2:NO-MATCH, 10.10.1.50:2427, 10.101.20.50:2427
May 18 08:54:48.718: aaln/S2/3:NO-MATCH, 10.10.1.50:2427, 10.101.20.50:2427
May 18 08:54:48.718: aaln/S2/4:NO-MATCH, 10.10.1.50:2427, 10.101.20.50:2427
May 18 08:54:48.718: aaln/S2/5:NO-MATCH, 10.10.1.50:2427, 10.101.20.50:2427
May 18 08:54:48.718: aaln/S2/6:NO-MATCH, 10.10.1.50:2427, 10.101.20.50:2427
May 18 08:54:48.718: aaln/S2/7:NO-MATCH, 10.10.1.50:2427, 10.101.20.50:2427
May 18 08:54:48.718: aaln/S2/8:NO-MATCH, 10.10.1.50:2427, 10.101.20.50:2427
May 18 08:54:48.718: aaln/S2/9:NO-MATCH, 10.10.1.50:2427, 10.101.20.50:2427
May 18 08:54:48.718: aaln/S2/10:NO-MATCH, 10.10.1.50:2427, 10.101.20.50:2427
May 18 08:54:48.718: aaln/S2/11:NO-MATCH, 10.10.1.50:2427, 10.101.20.50:2427
May 18 08:54:48.718: aaln/S2/12:NO-MATCH, 10.10.1.50:2427, 10.101.20.50:2427
May 18 08:54:48.718: aaln/S2/13:NO-MATCH, 10.10.1.50:2427, 10.101.20.50:2427
May 18 08:54:48.718: aaln/S2/14:NO-MATCH, 10.10.1.50:2427, 10.101.20.50:2427
May 18 08:54:48.718: aaln/S2/15:NO-MATCH, 10.10.1.50:2427, 10.101.20.50:2427
May 18 08:54:48.718: aaln/S2/16:NO-MATCH, 10.10.1.50:2427, 10.101.20.50:2427
May 18 08:54:48.718: aaln/S2/17:NO-MATCH, 10.10.1.50:2427, 10.101.20.50:2427
May 18 08:54:48.718: aaln/S2/18:NO-MATCH, 10.10.1.50:2427, 10.101.20.50:2427
May 18 08:54:48.718: aaln/S2/19:NO-MATCH, 10.10.1.50:2427, 10.101.20.50:2427
May 18 08:54:48.718: aaln/S2/20:NO-MATCH, 10.10.1.50:2427, 10.101.20.50:2427
May 18 08:54:48.718: aaln/S2/21:NO-MATCH, 10.10.1.50:2427, 10.101.20.50:2427
May 18 08:54:48.718: aaln/S2/22:NO-MATCH, 10.10.1.50:2427, 10.101.20.50:2427
May 18 08:54:48.718: aaln/S2/23:NO-MATCH, 10.10.1.50:2427, 10.101.20.50:2427
May 18 08:54:48.766: MGCP Packet received from 10.10.1.50:2427--->
500 30552324
May 18 08:55:18.709: MGCP Packet sent to 10.10.1.50:2427--->
RSIP 30552326 *@voip-010.corporateict.domain MGCP 0.1
RM: graceful
May 18 08:55:18.713: MGCP Packet sent to 10.101.20.50:2427--->
RSIP 30552328 *@voip-010.corporateict.domain MGCP 0.1
RM: restart
May 18 08:55:18.713: MGCP Packet received from 10.10.1.50:2427--->
200 30552326
May 18 08:55:18.713: [S] mgcp_msg_ack:6152,Updating (*)=10.10.1.50
May 18 08:55:18.713: *:NO-MATCH, 10.101.20.50:2427, 10.10.1.50:2427
May 18 08:55:18.713: aaln/S*/*:NO-MATCH, 10.101.20.50:2427, 10.10.1.50:2427
May 18 08:55:18.713: aaln/S2/*:NO-MATCH, 10.101.20.50:2427, 10.10.1.50:2427
May 18 08:55:18.713: aaln/S2/0:NO-MATCH, 10.101.20.50:2427, 10.10.1.50:2427
May 18 08:55:18.717: aaln/S2/1:NO-MATCH, 10.101.20.50:2427, 10.10.1.50:2427
May 18 08:55:18.717: aaln/S2/2:NO-MATCH, 10.101.20.50:2427, 10.10.1.50:2427
May 18 08:55:18.717: aaln/S2/3:NO-MATCH, 10.101.20.50:2427, 10.10.1.50:2427
May 18 08:55:18.717: aaln/S2/4:NO-MATCH, 10.101.20.50:2427, 10.10.1.50:2427
May 18 08:55:18.717: aaln/S2/5:NO-MATCH, 10.101.20.50:2427, 10.10.1.50:2427
May 18 08:55:18.717: aaln/S2/6:NO-MATCH, 10.101.20.50:2427, 10.10.1.50:2427
May 18 08:55:18.717: aaln/S2/7:NO-MATCH, 10.101.20.50:2427, 10.10.1.50:2427
May 18 08:55:18.717: aaln/S2/8:NO-MATCH, 10.101.20.50:2427, 10.10.1.50:2427
May 18 08:55:18.717: aaln/S2/9:NO-MATCH, 10.101.20.50:2427, 10.10.1.50:2427
May 18 08:55:18.717: aaln/S2/10:NO-MATCH, 10.101.20.50:2427, 10.10.1.50:2427
May 18 08:55:18.717: aaln/S2/11:NO-MATCH, 10.101.20.50:2427, 10.10.1.50:2427
May 18 08:55:18.717: aaln/S2/12:NO-MATCH, 10.101.20.50:2427, 10.10.1.50:2427
May 18 08:55:18.717: aaln/S2/13:NO-MATCH, 10.101.20.50:2427, 10.10.1.50:2427
May 18 08:55:18.717: aaln/S2/14:NO-MATCH, 10.101.20.50:2427, 10.10.1.50:2427
May 18 08:55:18.717: aaln/S2/15:NO-MATCH, 10.101.20.50:2427, 10.10.1.50:2427
May 18 08:55:18.717: aaln/S2/16:NO-MATCH, 10.101.20.50:2427, 10.10.1.50:2427
May 18 08:55:18.717: aaln/S2/17:NO-MATCH, 10.101.20.50:2427, 10.10.1.50:2427
May 18 08:55:18.717: aaln/S2/18:NO-MATCH, 10.101.20.50:2427, 10.10.1.50:2427
May 18 08:55:18.717: aaln/S2/19:NO-MATCH, 10.101.20.50:2427, 10.10.1.50:2427
May 18 08:55:18.717: aaln/S2/20:NO-MATCH, 10.101.20.50:2427, 10.10.1.50:2427
May 18 08:55:18.717: aaln/S2/21:NO-MATCH, 10.101.20.50:2427, 10.10.1.50:2427
May 18 08:55:18.717: aaln/S2/22:NO-MATCH, 10.101.20.50:2427, 10.10.1.50:2427
May 18 08:55:18.717: aaln/S2/23:NO-MATCH, 10.101.20.50:2427, 10.10.1.50:2427
May 18 08:55:18.765: MGCP Packet received from 10.101.20.50:2427--->
500 30552328
We have an another VG224 at an another site, it registers to its CUCM. The same/similar configuration than the fact that I have
ccm-manager config
in this VG224. I understand it is required for the registration part. And, physically, we have only the first of 24 lines are connected. Do I need to configure/associate end-point for that first line in CUCM for VG224 to be registered?
Thank you & regards,
Lay
Make sure that the VG224 is registered to CUCM with the correct MAC address from the FastEthernet interface of the VG224.
Id get rid of the domain name information and try via IP only and see if this works. If CUCM can not resolve the hostname of the VG224, it will no register. At least with IP, you know its not DNS related
