02-01-2018 02:24 PM - edited 03-17-2019 12:06 PM
Does anyone know if a VG224 or VG248 will "work" with CUCM 11.5?
Solved! Go to Solution.
02-01-2018 02:35 PM
Hello dmcgary,
According to CUCM compatibility Matrix in here: https://www.cisco.com/c/dam/en/us/td/docs/voice_ip_comm/uc_system/unified/communications/system/Compatibility/CSR-Compatibility-Matrix-InteractiveHTML.html
Yes VG224 should work, with software version 15.1(4)M10 and VG248 should work with software version 1.3(2).
Best Regards, Jaime.
Please rate if you find this answer helpful.
02-01-2018 02:35 PM
Hello dmcgary,
02-02-2018 06:08 AM
Thank you for your quick response!
10-23-2022 03:29 AM
10-23-2022 05:33 AM
As you question is off topic of the OP I’d recommend you to post your question in your own post.
02-01-2018 02:42 PM
02-02-2018 06:07 AM
We have many of these, and have been slowly moving to VG310 and ATA190's. We will do this over several years, as budgets are tight.
