VG224, VG248 and CUCM 11.5
dmcgary
Does anyone know if a VG224 or VG248 will "work" with CUCM 11.5?
Hello dmcgary,
According to CUCM compatibility Matrix in here: https://www.cisco.com/c/dam/en/us/td/docs/voice_ip_comm/uc_system/unified/communications/system/Compatibility/CSR-Compatibility-Matrix-InteractiveHTML.html
Yes VG224 should work, with software version 15.1(4)M10 and VG248 should work with software version 1.3(2).
Best Regards, Jaime.
Please rate if you find this answer helpful.
6 Replies 6
Hello dmcgary,
Thank you for your quick response!
What if im planning to use SIP VG224 ?? could i still use them with BE7000M(M5)A ??? Also i attached copy of VGs Confiuration if needed
As you question is off topic of the OP I’d recommend you to post your question in your own post.
Response Signature
R0g22
Why not move to VG-3XX ? VG-224 is still fine but VG-248 is extinct. :)
We have many of these, and have been slowly moving to VG310 and ATA190's. We will do this over several years, as budgets are tight.
