VG224 with CME by sccp
Faisal.Saoud
Level 3
Level 3
Hi Folks,
I tried to connect vg224 with cme 2851 by sccp, and once i finished the configuration as shown below, i listen fast busy tone once i off hook the analoge phone, and make sh ephone on CME:
CME#sh ephone
ephone-2[1] Mac:2C3F.38C9.1007 TCP socket:[1] activeLine:0 whisperLine:0 REGISTERED in SCCP ver 22/17 max_streams=5
mediaActive:0 whisper_mediaActive:0 startMedia:0 offhook:0 ringing:0 reset:0 reset_sent:0 paging 0 debug:0 caps:9
IP:192.168.1.11 * 49613 7962  keepalive 388 max_line 6 available_line 6
button 1: cw:1 ccw:(0 0)
  dn 2  number 200 CH1   IDLE         CH2   IDLE
Preferred Codec: g711ulaw
Lpcor Type: none
ephone-3[2] Mac:C08C.6055.2400 TCP socket:[-1] activeLine:0 whisperLine:0 UNREGISTERED
mediaActive:0 whisper_mediaActive:0 startMedia:0 offhook:0 ringing:0 reset:0 reset_sent:0 paging 0 debug:0 caps:0
IP:0.0.0.0* 0 Unknown 0  keepalive 0 max_line 0 available_line 0
  dn 3  number 300 CH1   DOWN         CH2   DOWN
Lpcor Type: none
this is configuration on CME:
CME#sh run
Building configuration...
Current configuration : 1490 bytes
! Last configuration change at 17:23:00 UTC Thu Oct 12 2017
version 15.1
hostname CME
boot-start-marker
boot-end-marker
no aaa new-model
dot11 syslog
ip source-route
ip cef
no ipv6 cef
voice service voip
voice class codec 1
 codec preference 1 g711ulaw
 codec preference 2 g729r8
 codec preference 3 g711alaw
voice-card 0
license udi pid CISCO2851 sn FCZ1422714A
interface GigabitEthernet0/0
 duplex auto
 speed auto
interface GigabitEthernet0/1
 no ip address
 shutdown
 duplex auto
 speed auto
ip forward-protocol nd
no ip http server
no ip http secure-server
control-plane
mgcp profile default
telephony-service
 max-ephones 110
 max-dn 288
 ip source-address 192.168.1.1 port 2000
 system message ACT
 max-conferences 8 gain -6
 transfer-system full-consult
 create cnf-files version-stamp Jan 01 2002 00:00:00
ephone-dn  2  dual-line
 number 200
ephone-dn  3  dual-line
 number 300
ephone  2
 mac-address 2C3F.38C9.1007
 type 7962
 button  1:2
ephone  3
 mac-address C08C.6055.2400
 max-calls-per-button 2
 type anl
 button  1:3
line con 0
line aux 0
line vty 0 4
 login
 transport input all
scheduler allocate 20000 1000
end
CME#
Configuration on VG224:
vg224#
vg224#sh run
Current configuration : 1579 bytes
! Last configuration change at 03:09:11 UTC Mon Mar 1 1993
version 15.1
no service pad
hostname vg224
boot-start-marker
boot-end-marker
no aaa new-model
ip source-route
ip cef
no ipv6 cef
stcapp ccm-group 1
stcapp
voice-card 0
interface FastEthernet0/0
 ip address 192.168.1.2 255.255.255.0
 duplex auto
 speed auto
interface FastEthernet0/1
 no ip address
 shutdown
 duplex auto
 speed auto
no ip http server
control-plane
voice-port 2/0
 timeouts ringing infinity
voice-port 2/1
voice-port 2/2
voice-port 2/3
voice-port 2/4
voice-port 2/5
voice-port 2/6
voice-port 2/7
voice-port 2/8
voice-port 2/9
voice-port 2/10
voice-port 2/11
voice-port 2/12
voice-port 2/13
voice-port 2/14
voice-port 2/15
voice-port 2/16
voice-port 2/17
voice-port 2/18
voice-port 2/19
voice-port 2/20
voice-port 2/21
voice-port 2/22
voice-port 2/23
ccm-manager config server 192.168.1.1
ccm-manager config
ccm-manager sccp local FastEthernet0/0
ccm-manager sccp
sccp ccm 192.168.1.1 identifier 1 version 7.0
sccp
sccp ccm group 1
 bind interface FastEthernet0/0
 associate ccm 1 priority 1
dial-peer voice 1 pots
 service stcapp
 port 2/0
line con 0
line aux 0
line vty 0 4
 login
 transport input all
end
vg224#
vg224#
vg224#
*Mar  1 03:46:25.911: cmapp_sccp_tftp_download_file: Unable to get configuration file size tftp://192.168.1.1/SKIGW8C60552EE1.cnf.xml, rc=-2
vg224#
Ho can I solve this problem?
Faisal.Saoud
Level 3
Level 3
Any update plz
Please Guys, I need help in this problem?
