VG224 with CUCM 11.X
Leonardo Santana
VG224 is not supported with CUCM 11.X?
http://www.cisco.com/c/en/us/td/docs/voice_ip_comm/uc_system/unified/communications/system/versions/IPTMtrix.html#pgfId-1163273A
At the matrix of compatibility does not show the recommended IOS Version.
Leonardo Santana
Leonardo Santana
*** Rate All Helpful Responses***
Aman Soi
Hi Tadeu,
checked the link shared you which shows vg224 as Blank in CUCM 10.5.
Not aware whether VG224 is supported with CUCM11 but I checked in CUCM 10.5.1 , VG 224/VG202/VG310/VG320/VG350 are supported .
regds,
aman
Jaime Valencia
It is supported, you probably want to use a higher release (if available) from the one listed on 10.5, or at the bare minimum, the same as 10.5
java
if this helps, please rate
