02-16-2011 01:28 PM - edited 03-16-2019 03:30 AM
Greetings,
Trying to get a definitive answer as to if initiating a MeetMe conference is supported on a VG248. All the posts I am reading say it can only be done on a SCCP device, but the VG248 is a SCCP device. We have it working successfully from a VG224 configured for SCCP, just need to know if it should work on a VG248.
Yes, I now the VG248 is a dead product, but we have some and need to use them.
Mark
Solved! Go to Solution.
02-16-2011 02:19 PM
You cannot start a meetme from a VG248
java
If this helps, please rate
www.cisco.com/go/pdihelpdesk
02-16-2011 02:19 PM
java
02-16-2011 05:26 PM
Thanks!
