VG248 and MeetMe
ahochau_2
Greetings,
Trying to get a definitive answer as to if initiating a MeetMe conference is supported on a VG248.  All the posts I am reading say it can only be done on a SCCP device, but the VG248 is a SCCP device.  We have it working successfully from a VG224 configured for SCCP, just need to know if it should work on a VG248.
Yes, I now the VG248 is a dead product, but we have some and need to use them.
Mark
Jaime Valencia
You cannot start a meetme from a VG248
Supported Analog Telephony Features
http://www.cisco.com/en/US/docs/voice_ip_comm/vg248/1_3_1/english/configuration/guide/vg248swo.html#wp1025375
java
If this helps, please rate
www.cisco.com/go/pdihelpdesk
java
if this helps, please rate
Jaime Valencia
java
java
Thanks!
