11-09-2018 07:46 AM - edited 03-17-2019 01:42 PM
Hi VG248 interface is down. The interface is connected to switch. we confirmed the switch port is good. and we can logon to it by console. Anyone can give some suggestion? Thank you
11-10-2018 03:17 AM
First make sure physical link is up/down. If down login to core switch and check "show cdp neighbors"
Or else connect to console and verify VG interface IP address, Speed, Duplex and ip route settings.
Ram.S
11-10-2018 08:00 AM
Thank you so much for your reply.
We confirmed the physical switch port and the cable are good. but the issue is VG248 port which is connected to the switch is down. The switch cannot see this cdp neighbor and cannot see VG248 port. It is NIC port issue of VG248. but how can we further confirm this from VG248 side?
After connected to it by console, we can see configuration is same as before. and not find any issue
11-10-2018 11:53 AM
11-10-2018 05:51 PM
i agree, but it would bring some compatibility issue with other VG248 and CUCM etc.
11-11-2018 04:39 PM - edited 11-11-2018 04:39 PM
Ok, I'll bite: what incompatibility does a VG310/320 create with the VG248 inventory in your environment? They are supported as far back as CUCM 9.1(2)SU2, have a compatible T.38 NSE-based fax relay switchover, and the VG248 never supported modem or text relay in the first place.
