01-29-2018 12:16 PM - edited 03-17-2019 12:04 PM
We are setting up a new small branch office that will be running of a centralized CUCM cluster. When going to purchase the router we were going to use a 4321 and also get a VG310 as there are a number of analog lines required at this site. It was then I realized I could get a PRI card on the VG310 and I was wondering is there a reason I wouldn't just use the VG310 (Other than SRST which I do not think a VG310 can do).
Solved! Go to Solution.
01-29-2018 07:19 PM
● The VG310 and VG320 can support foreign exchange office (FXO), foreign exchange station (FXS), T1/E1 Primary Rate Interface (PRI), channel associated signaling (CAS), and Basic Rate Interface (BRI) 2- and 3-port voice interface cards (Cisco VIC2 and VIC3, respectively).
https://supportforums.cisco.com/t5/ip-telephony/using-a-vg310-as-a-voice-router-w-pri/td-p/2695629
01-29-2018 04:36 PM
01-29-2018 07:07 PM - edited 01-29-2018 09:38 PM
01-29-2018 07:19 PM
