VG310
Peace2you
Is it possible to connect 2 analog phones using the same extension on the same vg310 port?
balaji.bandi
No you can not i guess.
BB
George Sotiropoulos
I believe that this is possible, considering that on the CUCM for the VG202, you are able to configure the same line (no error on CUCM)VG1.png
In my example, if you click on the FXS 0/0/0 and on the FXS0/0/1 you are able to set the same number (similar to a common line on Cisco Phones).
Its worth trying it out and letting us know,
George
Hope the above helps,
gsotirop
Good one @George Sotiropoulos , the same number is possible? or we are trying here?
BB
Hello @balaji.bandi ,
While testing the VG202 (as shown on the photo) I was able to set the same DN on both Analogue Phones. At least in terms of CUCM it doesnt seem to be an issue. Unfortunately, the VG is at a Remote site so I cannot dial to test the calling schene.
George
gsotirop
