03-05-2017 08:34 PM - edited 03-17-2019 09:43 AM
I created a bat sheet to import 48 ports. , the first 24 ports imported perfectly however the second card failed. It was subunit 1 that failed.
I cannot see an error and the fact the first 24 ports worked means my import sheet is at least half good.
Any ideas?
03-05-2017 09:16 PM
Hi Mike,
It could be due to numbering of slots in the BAT file. For example, in the BAT file you could have the slots numbered as 0-47 instead of 0-23 on slot 0/0 and then from 0-23 on slot 0/1.
Please check if that is the case here.
Manish
03-06-2017 09:14 AM
Manish , thanks for response, I still cannot get the second card to be recognized by bat, It seems to want to add another gateway.
I have tried hex , decimal everything I can think of and no luck. If I add them manually on second card all is okay it is just bat that is messed up.
I will keep trying but thanks again for the reply
04-16-2020 01:48 AM
I am having the same issue, did you find a solution?
04-16-2020 03:30 AM
Make sure that the format of the file is correct. This is from the sample file in CM 12.5.
For SCCP Gateway:
Sample string from CSV file:
DOMAIN NAME,DESCRIPTION,SLOT,SUBUNIT,PORT NUMBER,PORT DESCRIPTION,PORT DIRECTORY NUMBER
SKIGW1111111111,test,2,0,0,sample,1000
For SCCP gateway with some device and line fields:
DOMAIN NAME,DESCRIPTION,SLOT,SUBUNIT,PORT NUMBER,PORT DESCRIPTION,PORT DIRECTORY NUMBER,CSS,ROUTE PARTITION,DISPLAY
SKIGW1111111111,test,2,0,0,test,1111,,p1,
|_____________| |___|| | | |__| |___| |
| | | | | | | Route Partition(50 characters, optional)
| | | | | | Port Directory Number(24 digits, optional)
| | | | | Port Description (50 characters, optional)
| | | | Port NUmber (3 digits,optional)
| | | SubUnit (3 digits, madatory *, default to 0)
| | Slot (3 digits, madatory *, default to 2)
| Description(upto 100 characters, optional)
MAC Address( 15 digits ,mandatory *)
For blank values in CSV, values from template would be considered.
For SCCP gateway with more than one port configured :
SKIGW4224224224,VG320_test2,0,1,0,,1026
SKIGW4234234234,VG320_test3,0,2,0,,1027
SKIGW4254254254,VG320_test4,0,1,1,,1028
