VG320 SCCP Config
Mark Dragone
Beginner
Beginner
Hi All
I have a question regarding a VG320 programmed as SCCP.  Whenever the VG320 is reloaded, due to power failure or whatever, the "stcapp feature speed-dial" returns in the programming of the gateway.  I then need to go in and issue the "no stcapp feature speed-dial" command in order to once again disable it as i do not want it enabled.  Wr mem is always done after making the change.  Any thoughts as to why this would be happening.
Rob Huffman
Hall of Fame Community Legend Hall of Fame Community Legend
Hi Mark,
I did see a similar thread with a good response from Tere @Cisco;
https://supportforums.cisco.com/discussion/11794771/vg224-disable-stcapp-feature-speed-dial
Cheers!
Rob
Recognize Your Peers
