VG350- DSP sizing
abdulkarim041
Level 2
Level 2
I am going to design VG350 for my client. My question is how would size the DSP value?
BR
Abdul Karim
D_Lebedev
Level 3
Level 3
Try to check it with Cisco DSP calculator.
http://www.cisco.com/web/applicat/dsprecal/dsp_calc.html
Hope it helps.
Manish Gogna
Hi Abdul,
VG350 is basically a 3945 with 144 FXS ports and a PVDM3-256 module. DSP credit calculations are the same
https://puck.nether.net/pipermail/cisco-voip/2013-April/032045.html
DSP calculator does not have the option for VG350, so you need to do your sizing based on above info.
Manish
