VG350 Support in CUCM 7.1.3
Chris Pohlad-Thomas
Based on the data sheet for the VG350 I do see that version 7.1 of CUCM is supported. I assume this is via a dev pack? I can't seem to find anything on adding support or what version of the dev pack should be loaded. I am trying to estimate configuration time for a customer. I am assuming like with any device the dev pack would need to be uploaded and installed and then the cluster rebooted to add support for the new device.
Mohammed Khan
VG350 is not compatible with this CUCM version 7.1.
It is however;  is supported on CUCM 8.6.2(SU2), 9.0.1 or higher.. Also, make sure the VG350 uses the minimum IOS version of '15.2(4)M'
Check below compatibility matrix
Cisco Collaboration Systems Release Summary Matrix for IP Telephony
http://www.cisco.com/c/en/us/td/docs/voice_ip_comm/uc_system/unified/communications/system
/versions/IPTMtrix.html
HTH,
Mohammed Noor
[+5] to Noor.
Hi Thomas,
Please refer the datasheet which says
Compatibility
Cisco IOS Software Release
15.2(4)M or later
Cisco Unified Communications Manager Version
http://www.cisco.com/c/en/us/products/collateral/unified-communications/vg-series-gateways/data_sheet_c78-710996.html
regds,
aman
